could also be loose wheel speed sensors, bad abs motor, bad wheel bearings, worn brakes.... any of those and more.
cheap check... look at the sensors, you can tell if they are loose or if the wire is corroded.
check the wheel bearing. elevate the front end off the ground, grab the wheel at the 12 and 6 oclock postions and try to rock the wheel. if there is ANY play, bearings are worn.
check the pads a rotors. check the rear wheel bearing seals. if those go bad, it can fill your e brake drums.
i think you'll need to find someone with a T2 to check the abs motor....
hom many miles?? how many on bearings, pads, rotos and such.
I'll check all of that in the morning too.
93,000..original bearings...pads have 15,000 on them...rotors turned....
No sign of wheel seals leaking. But the brakes have gotten spongy within the last few weeks.
