Router problem?
Farmdog
the 'Traveling Can' started here
Iowa, the one w/o 'taters
I've now narrowed my problem down to my router, your standard Linksys Wireless-G 2.4 GHz.
I recently received new wireless equipment from my service provider. My laptop works fine away from my network.
The problem; Occassionaly my service slows to a creep or stalls altogether. There are a couple of sites that will really load in their intirety.
Does it sound like I have the problem figured out or not enough info? Any suggestions on a new router if that's it?
more info...what is your ISP, to you have wep enabled, how many computers do you have on the network
My service provider is a local telephone company that has several wireless networks in the area. Two computers on the network, one via ethernet cable directly from the router, one wirelessly. What is this 'web enabled' of which you speak?
Also, when I'm having problems unplugging the router for a minute usually solves it.
I might also add, when I'm listening to a live stream of radio, you can tell when the connection slows. The audio will get choppy or stop altogether.
