Reset Taps
Can I reset the taps without the laptop? Or can I with the laptop without loading a tune?
thanks
You'll need a laptop to do this. Go to Scan Tool, then the "DVT" tab and select "clear all adapts".
exactly.
you will have to check the activate box too.
Then run through all of the gears a few times at part throttle
the half throttle
then 3/4 throttle
then WOT
then hit T/H and repeat. After that you should have learned her good.
