Just finished changing out the injector nozzles, started up fine, let it idle for a while while I took stuff out of the bed, then took it for a test drive. Was running good initially. Then I did a medium acceleration run with it(3000 rpm), ok at first, then saw blue smoke after shift to 3rd. Slowed down, sped up, ok.
Slowed down, then accelerated mildly through the gears, blue smoke as it shifted into higher gears. Slowed to turn around, running rough. Took it back home. As I slowed for a corner running not too bad, came to another corner running rougher(missing) blue smoke even when driving slow to the house.
Shut it down and did a visual, no leaks, no spewing, but... (edit: found the coolant to be a little dark. That settled out later). I have searched both here and at the "Place" couldn't find anything about oil in coolant(disregard, no oil in coolant)(I may not know how to do the most effective search, but I tried what I know).
I'm a self employed carpenter and this is my bread and butter truck. I'm going to pull the glow plugs to see if I can isolate the affected cylinder(s). I'm hoping its just a head gasket. Whatever input you foks can throw my way would be appreciated.
1993 GMC 3500. Stock except, 3" down pipe, 3" straight exhaust. 215,000 miles. Injectors were original as far as I know.
