jettech
I found an issue with the Titan tank that I would suggest everyone look at if they have one installed. I looked at my fuel cooler area to follow up on a post some else asked about ( on another site) regarding a clearance issue they were having when they installed their tank. Anyone who has installed the Titan tank knows the fwd brace is not the most secure setup and could be a lot better. I found another issue. The entire tank and optional skid shield shifted slightly toward the passenger side and the tank also slid slightly fwd inside the skid shield. It probably moved ¾ to 1 inch toward the passenger side in the fwd cradle by bending the cradle and causing it to flatten out the normal U shape that is supposed to retain the tank in place. It shifted fwd about ½ to ¾ inch inside the optional shield. By moving toward the passenger side it comes closer to the drive shaft, I don’t think I need to tell you how ugly that could become. By sliding fwd in the shield it causes the tank to come closer to the fuel cooler which could cause rubbing issues if it goes far enough to contact the cooler. I ended up putting a floor jack under the front of the tank and removing the fwd brace. I bent the cradle back into shape, fabricated and welded in some gussets to stop it from shifting to the right again and bending the cradle. I was able to get a cheap scissor jack between the front of the tank and the torsion bar and use it to push the tank to the rear, it just slide back inside the skid shield. Then I used a small piece of angle iron and positioned it at the front end of the tank and bolted it to the shield to keep it from sliding fwd again.
