Radio Gremlins
toddlnrd
My first diesel!
Garner, NC
I have been trying to chase this rabbit on my own since Father's Day. My factory radio clock resets to 1:00 almost every time I start the truck. Also, the factory CD player does not work now.
It all started when I hooked up a trailer and it blew the fuse for my brake lights and turn signals. I found that fuse and replaced it, but the clock is still messed up.
I have check every other fuse in the driver's side fuse panel. Is there someplace else to check for fuses?
Strange thing also is that the preset channels are still programmed.
Any suggestions would be much appreciated.
Todd
You checked both the fuse/relay center under the hood, as well as the one on the side of the instrument cluster?
EDIT: There's a 3rd one almost directly behind the e-brake pedal...I know it has the damned ding-ding box for the lights on, key in, door ajar, seatbelt... I hated that thing, mine used to ride in the center console.
