Can anybody tell me how I could check my D/A for a leaky headgasket.The engine is usin a little water & no leaks anywere.Checked the exhaust & dry as can be too.I know a gas engine you take a compression check through the plug holes.How do you do it with a Diesel?Pull the injectors,yikes.It takes anyweres from 1 quart to a half gallon a month.Were Im at is extremely hot here,heat index from 105-112. I wonder if it isnt evaporating as the hot air is going trough the radiator core.If it sits it dos'nt use it.I do use the 50/50 mix from GM.The darn thing is running perfect far as performance & has all the power its putting out.Im pretty good at fiquring out a problem but this time I cannot find it or fiqure were the liquid is going.I even checked the cap to see if it was bypassing that down the overflow pipe,nothing.Sure am stumped with this problem.Even when temp is up to 195 I cannot detect the usage.I kinda thought that at that temp it would create more pressure on the system and show a leak if there was one somewere.I see the cap pressure on mine is 15 lbs.Even checked the heater core,nothing.Oil level is perfect to,right on the mark and no bubbles in it.Who ever gets the answer to this puzzle gets a free kangeroo with a saddle,50 jumps to the gallon.
