Put new in engine fuse box in truck also new ecu truck stop cranking sometimes when trying to start turn key agian an it starts its happening more .
Put new ecu an fuse box in 2003 durmax diesel stops cranking sometimes when trying to start.
  • What should I check
    Votes: 0 0.0%
  • Can you help
    Votes: 0 0.0%
  • Total voters
    0
What was the reason for replacing the ECU and the fuse box ?
Sounds to Me like a bad ignition switch, or, relay, or a bad connection in the start circuit.
Physically remove all fasteners holding down the ground wires and scrub and clean those surfaces until they are bright and shiny, and, while the negative battery cable is disconnected, do the same to all the connections on the positive side of the battery.
Fuse boxes are VERY common on those trucks. I would put a headlamp bulb ( better then a test light) on the s terminal of the starter and see if its dropping out when it stops cranking. That will narrow down a problem with the starter its self. If its loosing signal to the S terminal, work you way backwards through the system until you find was causing it. The Park/neutral safety switch on the trans could be the problem too, so I would check for constant power in crank at the PCM C1 connector pin 33. Also if you have a scanner you can watch the crank request PID to see if the PCM is being told to stop engaging the starter relay.
