pressure sending wire
Tag George
Illinois
Will be doing a 350 to 454 swap soon I hope. Any way I currently have a 95 350 TBI engine and I think I have the wires figured out but I have not started the work yet. Will the oil pressure sending wire reach? If not is there a available extension wire or do I just solder in a length of wire? If it is available where is it sold?
Isn't the pressure sensor based on resistance. I would imagine almost any good quality wire will suffice with a good connection. A little added resistance should interfere with the scale which is on upwards of several hundred of ohms over the scale I almost sure. The factory guage isn't all that accurate anyway but does the job.
