pics of banks crossover on soild axle truck/sub/blazer
Mikey von
Burney, CA
I have a banks crossover and it seems to not fit too well. The problem area I am running into is the bellhousing brace bracket (goes behind the motor mount and connects a brace to the bellhousing) on the drivers side. I will get some pics of this hopefully tonight.
My crossover is used and came with the two pieces together. I am trying to get it apart and see if I can get it to fit better.
Anyone have pics of a banks crossover on a 6.2l 4x4?
they do. My crossover hits the bracket under the motor mount. You can see it in both pics, but especially the second one. It is black with the single hole. It seems like the crossover should not be that close to the pan? I thought at first it was the custom pan, but it clearly is not and hits that bracket.
Banks made two different ones AFAIK. 2WD and 4wD.
hmmm, that may be the case, but even if it were a 2wd one, it seems pretty close. I would like to get the two pieces of pipe apart. Any tips? Of course I removed the clamps and have been using pb blaster.
