625fireman
I have injecter-itis
Cleaning up a little. have parts that I no longer need to keep around. I am in NE Ohio. zip code 44491. Shipping available on most parts in this list. I will be posting more once I go through the storage. Bumper, radiator, radiator support I will not ship. All parts are factory GM 1994, K3500, 4x4 floor shift, dually, automatic, F code, cab and chassis trucks. I bought 3 sister trucks from the municipality I work for. Ran 2 of them. Had on for parts. Trucks are gone. Selling what is left. If you dont like my price make offer I am pretty reasonable to deal with. Call, text 3306467163, or email [email protected]
Air box $10
Coolant tank $60
FFM $75
F Code Intake up & lower $200
Brake booster, master, and ABS comp (DUALLY) $100
Master cylinder (dually) $50
Engine cover $10
Fan Shroud $75
VSB $10
ECM with chip (BMRM) for factory setup listed above $100
EEPROM (BNTF) (for factory setup listed above expect for manual trans) $20
Radiator (has cooler) $75
Plastic insert for bumper $10
Under hood harness from fuse block across engine to ECM, to auto trans and transfer case. $100
In Dash harness fuse block included $50
Bumper $75
Washer fluid jugs with pump, (caps cracked) $10
Firewall relay, power strip cover $5
Air box $10
Coolant tank $60
FFM $75
Engine cover $10
Fan Shroud $75
VSB $10
Bumper $75
