D DMitch Recruit Messages 48 Reaction score 0 Location Vermont Jun 17, 2008 #1 What is normal idle oil pressure for an 08 LMM? Mine idles with about 25-30 and that seems low to me. Soon as I touch the throttle it jumps to 60 lbs. Thanks, Dan
saratoga Unpaid Help Messages 4,552 Reaction score 101 Location Lithia, FL Jun 17, 2008 #2 Normal. You probably see that once it's warmed up and idling; when it's cold it will idle ~60psi and jump to 90 when accelerating, correct?
D DMitch Recruit Messages 48 Reaction score 0 Location Vermont Jun 17, 2008 #3 No saratoga, cold engine it idles with about 30-35lbs pressure.
Wrecker The Oil Geek Messages 1,457 Reaction score 4 Location Beaver Falls, PA Jun 17, 2008 #4 What does it run hot?
D DMitch Recruit Messages 48 Reaction score 0 Location Vermont Jun 17, 2008 #5 Just a td lower hot. With any amount of throttle it jumps right up as it should. It's the idle pressure that seems low to me.
