Rodd
Recruit
Okay guy's hopefully someone can help me out here. My oil filter bypass that I just installed is leaking at the oil filters. The hose connections/hose clamps at the block adapter and the filter housing are clean. Facing the installed unit the barbs are on the Left and the right side holes of the housing have plugs in them. I used teflon tape on the barbs and the plugs and they are still white as can be. So the leak either has to be coming from between the filter gasket and the housing or the housing has a crack which I can't see.
Here is a bit more info...On the adapter that goes to the block there is a hole in the center and one on the outside. The center is the in and the outer is the out. So the "in" hose connects to the "out" on the filter housing and the "out" on the filter housing connects to the "in" at the block.
When I first installed it I accidentally had the hoses switched and ran 20 miles w/ no leaks. I then realized my mistake and switched the 2 hoses at the filter housing. Since then I have been leaking at the filters. I thought that the filters failed because I ran them wrong, so I put on 2 new filters and it still leaks. Maybe I should switch them back.
Help is greatly appreciated.
