At least you found out about it's design limit...:hihi:Well all I have left of that pump are in a clear plastic bag.
The one thing you want to keep right up front and personal.
The cooling system will not handle anything past about 300HP
This is the achiles heel of the design. The radiator and such simply will not reject the heat that you can build with all that fuel and power.
The Boat engines that Peninsular offers have a whole pond of COLD water to handle the task.
The frontal area of a Pickup and the limitations of the radiator size plus the fan and such all contribute to the power limits.
Jim Over at the page did a POWER project a few years back and they were able to manage 300HP and keep the heat in check.
A custom radiator may give you more room to play with, but the ability of the block design to reject heat is still a limiting factor.
Missy
