96Sub1500
Hello all,
I've been lurking for a little while on the diesel page and the truck stop. I really like this site, the knowledge, and how helpful everyone is. I've wanted a diesel truck for a while and my friend originally peaked my interests in the CUCV M1009 with promises of low miles and around $3k. I looked at everything diesel under $6k for a while (it would be a second vehicle and I will not finance) and saw older fords, chevs, and dodges. Another friend who does site work said only buy 7.3 powerstroke's younger than 97 or a duramax. Another said absolutely no to the 6.2 ("its a turd").
I looked and looked and looked. I like the cummins motor but once you add 4x4 and extended cab the price range goes up. I really like road tripping and don't have anything big to haul so I finally started looking at diesel burbs. I read almost every post on this site and learned the good and the bad about these motors.
I finally settled on one that was relatively close and in really good shape mechanically. The down side is 266k miles. The upside is two owners and the second kept all his receipts. I don't have any pictures yet (he already took down the craigslist ad) but its basically a:
1996 Suburban 1500 6.5TD
266,000 miles
Fully loaded
Some dashcracks and split front leather seat but everything else is near new inside
Ok paint (hood is going and roof could use some attention)
New GM replacement IP at 217k
A/C doesn't work (new compressor but leak at rear a/c)
New radiator
ABS was unplugged (light is on if I plug it in)
I've already recreated a maintenance and life cycle spreadsheet from carfax and the previous owner's receipts. He's been using synthetic in the motor which makes me feel like he at least did what he could to take care of it.
So on my basic list of to do's in order is:
EGT/FP/Trans/Boost gauges
Secure a spare motor (Teds maybe)
Diamond Eye 4"
K47 air box
Cooling system upgrades
Flashed ECM
ATT if the stocker ever blows out
First on my list though is doing something with the A/C. At some point the rear was serviced and the threads on the smaller line (at the rear junction) were messed up so JB weld was applied. Can the rear A/C be disconnected somewhere upfront and just run the front A/C?
Second, the ABS light is on. I've never had ABS so I'm not sure where to start. Just unplug it and drive it normally? I don't know if the problem is a wheel sensor or the actual unit. I am getting back my OBDII bluetooth module this week to check codes etc...
The truck starts right up after the glow light goes out. No real smoke. Runs good.
Is the best place to check blow by by pulling the CDR?
I'm still trying to get used to this diesel thing. I am so used to gas concepts and have years of reprogramming ECU's (mostly dodge turbo cars), building megasquirts, wideband O2, etc..... and now nothing is based on vacuum or AFR its all about EGT's (still baffles my that the motor doesn't "run away" like a gas motor would on fixed gas but unlimited air).
Hopefully I won't be tooo NOOB for you. I've been doing my reading.
Thanks!
Dylan
266,000 miles
Fully loaded
New radiator
Diamond Eye 4"
K47 air box
Flashed ECM
Thanks!
Dylan
