Yeah, the pass. manifold is a nightmare of engineering and bean counters clashing head to head and as usual, the bean counters won. If you look closely at it, you come to the realization that you have the exhaust gases from SIX cylinders (four driver's side plus #'s 6 & 8) trying to flow through the cross sectional area of TWO exhaust runners (and we wonder why the bottom end spooling response is shit on these motors) before joining with the exhaust flow from #'s 2 & 4 and up into the turbo. I've designed a vastly improved passenger side header-type exhaust manifold that keeps the driver's side exhaust flow separate from the passenger side until the two blend just below and are directed into the turbo. All the stock geometries are maintained, so that the crossover and turbo down pipes will bolt right up. The driver side cast iron manifold really isn't that bad of a design, but it too is also redone as a stainless steel header. The things one does with too much time on their hands and no money, to keep from going 'round the bend: Use that Physics Minor to do flow calculations to design and build the better mouse trap exhaust manifold for the passenger side out of 15 ga stainless tubing and 1/2" stock for the flanges. I have an acquaintance who owns a welding and fabrication shop who will do the TIG welding for me (I only own a MIG/wirefeed welder) as well as the CNC work for the head and turbo mount flanges, but it won't come cheap for this one-off (yes, we've discussed making jigs for replicating multiple copies, as well as patenting the design, that is also part of the cost) and since I went nearly 4 1/2 years without working since the accident, and now am only working 15-20 hours a week at near minimum wage, the new exhaust header is just a pipe dream (pun intended) for the foreseeable future. Should be able to pick up 10-15 "free" horsepower and about 30 lb/ft of torque over stock everything else unmodified, just like the center mount turbo models do. Add fueling and tuning and there should be really noticeable differences over comparable tunes using stock manifolds.
