need help truck has no power till 30
pongpromx
im having the same problem i think but maybe not i can floor it off a start and the truck has no balls and doesnt want to shift i let off it shifts i get over 30 and everything works fine and i dont think that its just gitting stuck in first gear because it wont even burn out and i also have a dummey light on but i dont have my manuel so i dont know what it means its a gas pump with 3 rain drops next to it
i have a 2004 F350 with the 6.0 and no clue what is wrong with it it has no balls till i hit 30. if i floor it from a stop the tires dont even try to spin it seams that it has a problem shifting out of first and once i get to 30 everythings fine and theres a dummey light on that i dont know what it is its a gas pump with 3 rain drops next to it
That probably means that you have water in your fuel. That should be the water in fuel light. You probably shouldnt run it at all until you change your fuel filter. Thats priority 1..!! Change it soon so you wont have to replace your injectors.
Ok I'll need more info on that... does it more hot or cold? any other lights on in the dash? Have it scanned? Fords have a ton of performance codes that DON'T turn on the check engine light.
