I'll be posting the problems that I've had with my New Truck. In no way this is meant to slam this fine truck.
My first problem was when I just took it home from the dealer. I was noticing this growling/rubbing noise coming from the steering. Took it to the dealer, they could not find the problem. Or replicate the noises.
Then several weeks later my glowplug module went out. Took it to the dealer,
they found out why the module was out. The Intermidiate Steering Shaft was bent like an elbow rubbing against the block and cut the glowplug wire. They warranty the ISS and Glowplug module. They could not figure out how the ISS got bent. Must have been from factory assemly.
