gahammerle
Saved by God's grace
Anyone see anything out of the ordinary or that should be different? Took these readings right after starting up while idling in park. All temps are F.
Boost Pressure MAP: 14.2
Desired EGR: 15.23
Desired Idle : 769
EGR Pressure: 14.43
EGR Duty Cycle: 0
Engine Coolant Temp: 70.4
Engine Speed: 788
Glow plug relay feedback: 0.1
Glow plug voltage: 0.2
Ignition voltage: 13.4
Wastegate Duty cycle: 99.6
Barometric Pressure: 13.56
Battery Voltage: 13.4
Fuel Temperature: 78.2
Intake air temp: 66.7
Throttle position: 0
Turbo Boost (Calculated): 0.64
Voltage reference sensor: 1.3
Actual Injection pump timing: 40.48
Cam reference missed: 0
Crank Reference missed: 0
Fuel calibration: 115
Fuel rate: 10
Injection Pulse width: 1.85
Injection timing - desired: 17.4
Injection timing - measured: 17.6
TDC Offset: -0.79
Current torque signal pressure: 25
Current transmission ratio: 1:04
Force motor DCS - duty cycle: 40.2
Force motor DCS - feedback current: 0.82
Force motor DCS - reference current: 0.82
TCC PWM solenoid duty cycle: 0
TCC slippage: 0
Tranny input speed: 659
Tranny output speed: 0
Tranny temp: 77.4
Turbine speed: 656
Vehicle speed: 0
No DTCs.
Would it be better to take readings when the engine is warm or while driving?
Desired EGR: 15.23
Desired Idle : 769
EGR Pressure: 14.43
EGR Duty Cycle: 0
Engine Speed: 788
Fuel rate: 10
TDC Offset: -0.79
TCC slippage: 0
Tranny temp: 77.4
Turbine speed: 656
Vehicle speed: 0
No DTCs.
