RNation
It's me again. For some reason in the morning when I go to start my truck to let it warm up the glow plug light comes on and stays on. I shut the the truck off after about 10 to 15 seconds though. Then I keep turning it of and on till it eventually works right. But this morning it wouldn't, no matter how many times I turned it on and off it came on and stayed on. I finally just unplugged the glow plug controller switch or the glow plug inhibitor switch (I forget what it's called), the one in the back of the driver side head with the 5 or 6 wires coming out of it. So far when I get the truck warmed up the glow plugs do go off and everything works fine, it's just the initial warm up that acts funny.
Doesn't the controller switch control the glow plugs on/off based on the coolant temp (I think there are 2 more temp sensors for glow plugs, 1 on opposite side of valley from controller switch and the other on passenger side next to back injector)? So if that's right my thoughts would be a faulty controller switch. Oh and the controller switch, glow plugs, the temp sensor on the passenger side back of head, ignition switch, and starter solenoid are new. I thought I had the glow plug system all covered but apparently not
