SmithvilleD
Active Member
(2) Moog K6693 ball joints - never installed or used
(2) Moog ES3609 tie rod ends - never installed - used for mock up & painted, never pressed in - no wear
(1) Moog K6654 - pitman arm - painted, never installed
(3 groove's in splines)
Ball joints were $41.97/ea from Summit Racing: $42 for both
Tie rod ends were $54.97/ea: $55 for both
Pitman arm was $78.97: $40
Shipping will be actual from my zipcode = 64089 USPS flat rate boxes are typically a good deal for this.
In general, they fit the GMT800 K2500HD trucks, but you must confirm they'll work for your application. Also confirm that you can use the 3 groove pitman arm, as there are both 3 groove & 4 groove applications.
This should be a good deal for anybody going thru the front end of a GMT800 Duramax truck.
Thanks for looking,
Darrin
Thanks for looking,
Darrin
