well in 2 hours today I have the 6.9 basically ready to pull. All thats left is to pull tunnel cover, 6 t-case bolts, supprt trans, drop x member, slide trans back and pull. Everything else is done, core support, radiator, fuel feed and return mount to x-member bolts, shafts... starter wiring... easy stuff to do when you just put the truck together in October.
