ripmf666
Registered user
<FORM onsubmit="JavaScript: return true;" method=post name=CellHandlerForm action=/si/cellHandler.do> Document ID: 884035 <HR>
Lower Oil Pan Removal
Tools Required
J 37228 Seal Cutter
<LI type=1>Disconnect the oil level sensor.
<LI type=1>Remove the lower oil pan bolts and nuts. Important: Do not damage the sealing surfaces when separating the lower oil pan from the upper oil pan.
<LI type=1>Separate the lower oil pan from the upper oil pan using J 37228 .- Remove the lower oil pan.
</FORM>
