ripmf666
Registered user
<FORM onsubmit="JavaScript: return true;" method=post name=CellHandlerForm action=/si/cellHandler.do>Document ID: 727532 <HR>
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=727532&from=sm#oth1-727532">Top View Components
<MAP name=692527.map><TABLE><TBODY><TR><TH align=left></TH></TR><TR><TD align=middle>(1)</TD><TD align=left>Fuel Injector Pipe (Cylinder 1)</TD></TR><TR><TD align=middle>(2)</TD><TD align=left>Fuel Injector Pipe (Cylinder 3)</TD></TR><TR><TD align=middle>(3)</TD><TD align=left>Fuel Injector Pipe (Cylinder 5)</TD></TR><TR><TD align=middle>(4)</TD><TD align=left>Fuel Injector Pipe (Cylinder 7)</TD></TR><TR><TD align=middle>(5)</TD><TD align=left>Right Fuel Rail</TD></TR><TR><TD align=middle>(6)</TD><TD align=left>Fuel Rail Bolts</TD></TR><TR><TD align=middle>(7)</TD><TD align=left>Left Fuel Rail</TD></TR><TR><TD align=middle>(8)</TD><TD align=left>Fuel Injector Pipe (Cylinder 2)</TD></TR><TR><TD align=middle>(9)</TD><TD align=left>Fuel Injector Pipe (Cylinder 4)</TD></TR><TR><TD align=middle>(10)</TD><TD align=left>Fuel Injector Pipe (Cylinder 6)</TD></TR><TR><TD align=middle>(11)</TD><TD align=left>Fuel Injector Pipe (Cylinder 8)</TD></TR><TR><TD align=middle>(12)</TD><TD align=left>Glow Plug Controller Bracket</TD></TR><TR><TD align=middle>(13)</TD><TD align=left>Glow Plug Controller (Federal Emissions)</TD></TR><TR><TD align=middle>(14)</TD><TD align=left>Glow Plug Controller (CA Emissions)</TD></TR><TR><TD align=middle>(15)</TD><TD align=left>Valve Rocker Arm Cover (Upper)</TD></TR><TR><TD align=middle>(16)</TD><TD align=left>Valve Rocker Arm Cover (Upper) Bolt</TD></TR><TR><TD align=middle>(17)</TD><TD align=left>Valve Rocker Arm Cover (Lower) Bolt</TD></TR><TR><TD align=middle>(18)</TD><TD align=left>Valve Rocker Arm Cover (Lower)</TD></TR><TR><TD align=middle>(19)</TD><TD align=left>Valve Rocker Arm cover Gasket</TD></TR><TR><TD align=middle>(20)</TD><TD align=left>Engine Assembly</TD></TR><TR><TD align=middle>(21)</TD><TD align=left>Valve Rocker Arm Cover Gasket</TD></TR><TR><TD align=middle>(22)</TD><TD align=left>Valve Rocker Arm Cover (Lower)</TD></TR><TR><TD align=middle>(23)</TD><TD align=left>Valve Rocker Arm Cover (Upper) Bolt</TD></TR><TR><TD align=middle>(24)</TD><TD align=left>Valve Rocker Arm Cover (Upper)</TD></TR></TBODY></TABLE>
© 2010 General Motors. All rights reserved.
</FORM></MAP>
