ripmf666
Registered user
<FORM onsubmit="JavaScript: return true;" method=post name=CellHandlerForm action=/si/cellHandler.do> Document ID: 798983 <HR>
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=798983&from=sm#oth1-798983">Intake and Exhaust Components-Federal Emissions
<MAP name=798866.map><TABLE><TBODY><TR><TH align=left></TH></TR><TR><TD align=middle>(1)</TD><TD align=left>Fuel Pipes Assembly</TD></TR><TR><TD align=middle>(2)</TD><TD align=left>Fuel Inlet Distribution Block</TD></TR><TR><TD align=middle>(3)</TD><TD align=left>Fuel Inlet Distribution Block Nut</TD></TR><TR><TD align=middle>(4)</TD><TD align=left>Fuel Inlet Distribution Block Bolt</TD></TR><TR><TD align=middle>(5)</TD><TD align=left>Fuel Pipe Bolt</TD></TR><TR><TD align=middle>(6)</TD><TD align=left>Fuel Pipe</TD></TR><TR><TD align=middle>(7)</TD><TD align=left>PCV Hose</TD></TR><TR><TD align=middle>(8)</TD><TD align=left>Intake Manifold Tube</TD></TR><TR><TD align=middle>(9)</TD><TD align=left>Turbocharger Boost Sensor Bracket</TD></TR><TR><TD align=middle>(10)</TD><TD align=left>Turbocharger Boost Sensor Bolt</TD></TR><TR><TD align=middle>(11)</TD><TD align=left>Turbocharger Boost Sensor</TD></TR><TR><TD align=middle>(12)</TD><TD align=left>Intake Manifold Tube Bolt</TD></TR><TR><TD align=middle>(13)</TD><TD align=left>Intake Heater Gasket</TD></TR><TR><TD align=middle>(14)</TD><TD align=left>Intake Heater</TD></TR><TR><TD align=middle>(15)</TD><TD align=left>Turbocharger Heat Shield (Upper)</TD></TR><TR><TD align=middle>(16)</TD><TD align=left>Turbocharger Heat Shield (Upper) Bolt</TD></TR><TR><TD align=middle>(17)</TD><TD align=left>Turbocharger</TD></TR><TR><TD align=middle>(18)</TD><TD align=left>Exhaust Outlet Adapter Gasket</TD></TR><TR><TD align=middle>(19)</TD><TD align=left>Exhaust Outlet Adapter</TD></TR><TR><TD align=middle>(20)</TD><TD align=left>Heat Shield</TD></TR><TR><TD align=middle>(21)</TD><TD align=left>Heat Shield Bolt</TD></TR><TR><TD align=middle>(22)</TD><TD align=left>Exhaust Outlet Adapter Nut</TD></TR><TR><TD align=middle>(23)</TD><TD align=left>Exhaust Outlet Adapter Stud</TD></TR><TR><TD align=middle>(24)</TD><TD align=left>Turbocharger Bolt</TD></TR><TR><TD align=middle>(25)</TD><TD align=left>Turbocharger Heat Shield (Lower)</TD></TR><TR><TD align=middle>(26)</TD><TD align=left>Intake Manifold</TD></TR><TR><TD align=middle>(27)</TD><TD align=left>Intake Manifold Bolt</TD></TR><TR><TD align=middle>(28)</TD><TD align=left>Exhaust Pipe Gasket</TD></TR><TR><TD align=middle>(29)</TD><TD align=left>Exhaust Pipe</TD></TR><TR><TD align=middle>(30)</TD><TD align=left>Exhaust Pipe Gasket</TD></TR><TR><TD align=middle>(31)</TD><TD align=left>Exhaust Pipe Bolt</TD></TR><TR><TD align=middle>(32)</TD><TD align=left>Exhaust Outlet Bracket</TD></TR><TR><TD align=middle>(33)</TD><TD align=left>Exhaust Pipe Bolt</TD></TR><TR><TD align=middle>(34)</TD><TD align=left>Exhaust Pipe Gasket</TD></TR><TR><TD align=middle>(35)</TD><TD align=left>Exhaust Pipe</TD></TR><TR><TD align=middle>(36)</TD><TD align=left>Heat Shield</TD></TR><TR><TD align=middle>(37)</TD><TD align=left>Heat Shield Bolt</TD></TR><TR><TD align=middle>(38)</TD><TD align=left>Exhaust Pipe Bolt</TD></TR><TR><TD align=middle>(39)</TD><TD align=left>Exhaust Pipe Gasket</TD></TR><TR><TD align=middle>(40)</TD><TD align=left>Exhaust Manifold Gasket</TD></TR><TR><TD align=middle>(41)</TD><TD align=left>Exhaust Manifold</TD></TR><TR><TD align=middle>(42)</TD><TD align=left>Exhaust Manifold Washer</TD></TR><TR><TD align=middle>(43)</TD><TD align=left>Exhaust Manifold Beveled Washer</TD></TR><TR><TD align=middle>(44)</TD><TD align=left>Exhaust Manifold Nut</TD></TR><TR><TD align=middle>(45)</TD><TD align=left>Heat Shield</TD></TR><TR><TD align=middle>(46)</TD><TD align=left>Heat Shield Bolt</TD></TR><TR><TD align=middle>(47)</TD><TD align=left>Exhaust Manifold Bolt</TD></TR><TR><TD align=middle>(48)</TD><TD align=left>Engine Assembly</TD></TR><TR><TD align=middle>(49)</TD><TD align=left>Exhaust Manifold</TD></TR><TR><TD align=middle>(50)</TD><TD align=left>Exhaust Manifold Bolt</TD></TR><TR><TD align=middle>(51)</TD><TD align=left>Heat Shield</TD></TR><TR><TD align=middle>(52)</TD><TD align=left>Heat Shield Bolt</TD></TR><TR><TD align=middle>(53)</TD><TD align=left>Exhaust Manifold Nut</TD></TR><TR><TD align=middle>(54)</TD><TD align=left>Exhaust Manifold Beveled Washer</TD></TR><TR><TD align=middle>(55)</TD><TD align=left>Exhaust Manifold Washer</TD></TR><TR><TD align=middle>(56)</TD><TD align=left>Exhaust Manifold Gasket</TD></TR><TR><TD align=middle>(57)</TD><TD align=left>Turbocharger Oil Supply Line Eye Bolt</TD></TR><TR><TD align=middle>(58)</TD><TD align=left>Turbocharger Oil Supply Line</TD></TR><TR><TD align=middle>(59)</TD><TD align=left>Intake Manifold Bolt</TD></TR><TR><TD align=middle>(60)</TD><TD align=left>Intake Manifold</TD></TR><TR><TD align=middle>(61)</TD><TD align=left>Intake Manifold Stud</TD></TR><TR><TD align=middle>(62)</TD><TD align=left>Intake Manifold Nut</TD></TR><TR><TD align=middle>(63)</TD><TD align=left>Intake Manifold Bolt</TD></TR><TR><TD align=middle>(64)</TD><TD align=left>Intake Manifold Stud</TD></TR><TR><TD align=middle>(65)</TD><TD align=left>Intake Manifold Tube Stud</TD></TR><TR><TD align=middle>(66)</TD><TD align=left>Intake Manifold Tube Gasket</TD></TR><TR><TD align=middle>(67)</TD><TD align=left>Intake Manifold Tube Nut</TD></TR></TBODY></TABLE>
© 2010 General Motors. All rights reserved.
</FORM></MAP>
