ripmf666
Registered user
<FORM onsubmit="JavaScript: return true;" method=post name=CellHandlerForm action=/si/cellHandler.do> Document ID: 799257 <HR>
Glow Plug Controller and Glow Plugs Removal
<LI type=1>Remove the intake air heater connector.
<LI type=1>Remove the glow plug harness bracket bolt. <LI type=1>Remove the glow plug harness nut from the left cylinder bank. <LI type=1>Remove the glow plug power feed wires from both cylinder banks. <LI type=1>Remove the glow plug controller nuts. <LI type=1>Remove the glow plug controller.
<LI type=1>Remove the glow plug harness nuts from the left cylinder bank. <LI type=1>Remove the glow plug harness from the left cylinder bank - 1 California, 2 Federal. <LI type=1>Remove the glow plugs from the left cylinder bank.
<LI type=1>Remove the glow plug harness nuts from the right cylinder bank. <LI type=1>Remove the glow plug harness from the right cylinder bank - 1 California, 2 Federal.- Remove the glow plugs from the right cylinder bank.
</FORM>
