ripmf666
Registered user
<FORM onsubmit="JavaScript: return true;" method=post name=CellHandlerForm action=/si/cellHandler.do> Document ID: 799255 <HR>
Fuel Injection Control Module Harness Assembly Removal
<LI type=1>Disconnect the four injector harness connectors. <LI type=1>Disconnect the turbocharger boost sensor connector.
<LI type=1>Disconnect the fuel injection control module connectors. <LI type=1>Disconnect the engine coolant temperature sensor connector.
<LI type=1>Disconnect the crankshaft position sensor connector.
<LI type=1>Remove the two engine block ground bolts from the right front side of the engine.
<LI type=1>Remove the main engine harness connector hold down bolts (1, 2). <LI type=1>Remove the main engine harness connectors.
<LI type=1>Remove the turbocharger coolant inlet hose from the turbocharger.
<LI type=1>Remove the water outlet bolts. <LI type=1>Remove the water outlet. <LI type=1>Remove the O-ring from the water outlet and discard.
<LI type=1>Disconnect the fuel rail pressure regulator valve connector. <LI type=1>Disconnect the fuel injection control module harness to the oil level sensor harness connector. <LI type=1>Disconnect the barometric pressure sensor connector.
<LI type=1>Disconnect the fuel temperature sensor connector.
<LI type=1>Disconnect the 3 fuel injector control module harness to glow plug controller connectors. <LI type=1>Remove the fuel injection control module harness assembly.
<LI type=1>Remove the main engine harness connector bracket bolts.- Remove the main engine harness connector bracket.
</FORM>
