ripmf666
Registered user
<FORM onsubmit="JavaScript: return true;" method=post name=CellHandlerForm action=/si/cellHandler.do>Document ID: 881762
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=881762&from=sm#oth1-881762">External Components
<MAP name=881719.map><TABLE><TBODY><TR><TH align=left></TH></TR><TR><TD align=middle>(1)</TD><TD align=left>Fuel Injection Control Module Bracket</TD></TR><TR><TD align=middle>(2)</TD><TD align=left>Fuel Injection Control Module Bracket</TD></TR><TR><TD align=middle>(3)</TD><TD align=left>Fuel Injection Control Module Bracket Bolt</TD></TR><TR><TD align=middle>(4)</TD><TD align=left>Fuel Injection Control Module Bolt</TD></TR><TR><TD align=middle>(5)</TD><TD align=left>Fuel Injection Control Module Bolt</TD></TR><TR><TD align=middle>(6)</TD><TD align=left>Bracket</TD></TR><TR><TD align=middle>(7)</TD><TD align=left>Fuel Injection Control Module Insulator</TD></TR><TR><TD align=middle>(8)</TD><TD align=left>Fuel Injection Control Module Sleeve</TD></TR><TR><TD align=middle>(9)</TD><TD align=left>Fuel Injection Control Module Insulator</TD></TR><TR><TD align=middle>(10)</TD><TD align=left>Fuel Injection Control Module</TD></TR><TR><TD align=middle>(11)</TD><TD align=left>Fuel Filter Assembly</TD></TR><TR><TD align=middle>(12)</TD><TD align=left>Engine Wiring Harness</TD></TR><TR><TD align=middle>(13)</TD><TD align=left>Flex Plate</TD></TR><TR><TD align=middle>(14)</TD><TD align=left>Dowel Pin</TD></TR><TR><TD align=middle>(15)</TD><TD align=left>Flywheel Washer</TD></TR><TR><TD align=middle>(16)</TD><TD align=left>Flywheel Bolt</TD></TR><TR><TD align=middle>(17)</TD><TD align=left>Flywheel (Manual Transmission)</TD></TR><TR><TD align=middle>(18)</TD><TD align=left>Flywheel (Automatic Transmission)</TD></TR><TR><TD align=middle>(19)</TD><TD align=left>Dowel Pin</TD></TR><TR><TD align=middle>(20)</TD><TD align=left>Ring Gear</TD></TR><TR><TD align=middle>(21)</TD><TD align=left>O-ring</TD></TR><TR><TD align=middle>(22)</TD><TD align=left>O-ring</TD></TR><TR><TD align=middle>(23)</TD><TD align=left>Engine Oil Cooler</TD></TR><TR><TD align=middle>(24)</TD><TD align=left>Oil Filter</TD></TR><TR><TD align=middle>(25)</TD><TD align=left>Engine Oil Cooler Bolt</TD></TR><TR><TD align=middle>(26)</TD><TD align=left>Oil Pressure Sensor</TD></TR><TR><TD align=middle>(27)</TD><TD align=left>Engine Assembly</TD></TR></TBODY></TABLE>
© 2010 General Motors. All rights reserved.
</FORM></MAP>
