I Need the GM part number for emergency brake cable 1994 K3500 crewcab long bed. Do
jrsavoie
Recruit
Rural Clifton, Illinois
Does anybody know where to find the number
Are there better quality aftermarket cables to be had?
Mine is frayed at the pedal.
Rock Auto has them listed as Parking Brake Cables
18P1361 or 18034279 is for a crew cab but it didn't list one for the long bed with crew...
Call them in the morning. Only $10 plus shipping.
15607677 04.779 CABLE, PARK BRK FRT (BROADCAST CODE XA) (54 9/16 INCHES LGTH) (W/BUTTON BOTH ENDS) (ACDelco #15607677) (USED W/LEVER W/REMOVABLE RUBBER PAD COVER) CK310 (C7A, C7E, C7L) (1ST DES) 1994-199401 5D2200A
15607678 04.779 CABLE, PARK BRK FRT (BROADCAST CODE XB) (78 11/16 INCHES LGTH) (W/BUTTON BOTH ENDS) (**VPI 1-877-846-8243) (USED W/LEVER W/REMOVABLE RUBBER PAD COVER) CK314 (C7A, C7E, C7L) 1994-199401 5D2200A
15735525 04.779 CABLE, PARK BRK FRT (ACDelco #15735525) (USED W/LEVER W/NON-REMOVABLE MOLDED PAD COVER) CK314 (C7A, C7E, C7L, 8S9) (2ND DES) 1994-199401
The dealer said he thought the number was G 15735528
But he definitely was not sure.
Pickup 4 X 4 1994
CK30943 L65 MT8
Disregard my first reply, Monday-itis struck again.
15644903 DISCON CABLE, PARK BRK FRT (96 INCHES LGTH) (BUTTON BOTH ENDS) (W/BROADCAST CODE OF ZW) (USED W/LEVER W/REMOVABLE RUBBER PAD COVER) CK3 (43) (1ST DES) 1994-199401 5D2200A
15735528 04.779 CABLE, PARK BRK FRT (2460 MM) (ACDelco #15735528) (USED W/LEVER W/NON-REMOVABLE MOLDED PAD COVER) CK3 (43) (2ND DES) 1994-199401
According to this you need to know which lever pad style you have
Dumb question, but how do you tell a removable pad from a non-removable pad?
I have removed things only to be told they really didn't come apart. And didn't see how some things that were supposed to come apart actually were to be dismantled.
Is the difference obvious?
Thanks
Jeff
No personal experience here; I guess I'd look at the molding lines on the backside of the pad to try and tell if it was molded around the pedal arm or if the opening is oversized enough to fit over the pedal. Or if your 96 is nearby to compare, it should have the non-removeable pad.
I checked the 94, 98 & 95. The emergency brake pedals are all the same. They appear to be removable. You can pull the rubber off where you would push down with your foot
Then you need 15644903 which unfortunately is discontinued, and nobody shows stock at this time. I guess aftermarket or used are the only options, or modifying one to work.
