High mount a/c for cummins swaps
Burning oil
LeroyDiesel.com
Vendor
Houston
View attachment cummins+high+mount+air+con+part#s[1].pdf
Hey everyone, for those of you planing on a Cummins swap the link above could be usefull. It has all the part # and pictures of the a/c high mount and alt hook up.
This is a post I saved from another web site that has long since been shut down.
I did do mine alittle differently as I wanted/need more belt wrap on the a/c. You will also need a compressor off a frieghtliner as the Dodge one will not work (its to short).
I will try to find a part # on the a/c I used.
The high mount bracket give you clearence at the frame rail.
what is the engine serial # for the high mount alt. awesome article, I m trying to get the engine back together and get it painted in the next few weeks.
Do you mean a part # for the ALT? Im not sure of a #, but I used a Delco 22SI 150 amp. Did that answer your ?
