MAGNUM SERVICES
Intelligence Guided By Experience
I posted a lot of things under the title Problem Still Happening! I have now REPLACED The LP, The PMD, The Fuel Filter and last The Fuel Tank! My tank had a lot of silver flakes of something that looks like the inside lining of the ORIGINAL Fuel Tank so I just bought a new one! I cleaned the sock on the fuel sending unit and after many,many tries I finally got the truck to start. It would run for a few seconds and quit. After many tries bleeding air from the fuel system I finally got it to run for a few minutes, then it would quit and be hard to start back! Again, running the LP while opening the fuel filter air bleed to push more air out. When running the LP I get a heavy volume of fuel out of the "T" valve but my pressure gauge is broken so I have no idea how much fuel pressure I have! When opening the bleeder valve on the Fuel Filter the fuel that comes out is very bubbly as it looks like there is still air in the system. After it quits when you open the air bleeder you get a hissing noise out of it! It ran for about four to five minutes then quit again but this time my SES Light came on and I will have to wait until a neighbor comes home to borrow his scanner. My truck has a lot of rust under it from six years of plowing and salting and I am going to try replacing ALL the fuel lines under it before I buy a IP! ANY IDEAS? ANY and ALL Replies will be greatly Appreciated! Thanks, Keith
