If you want a real answer, I would have it ceramic coated inside & out, Tech Line TLHB inside & turbo X outside, the inside will be coated with a ceramic thermal barrier , outside is a ceramic coat that is also a heat barrier/ corrosion stop, then you don't need anything else, you could spend the extra money and do it this way or wrap it and replace it when it rots out. Unless you have a blaster & 700deg oven to cur it, you would need to send it off and have it done. But it would last forever and would stop heat soak better than the wrap and a lot less trouble, and by the time you add up the cost of the good rap & ties, it will be about the same only look much better.
