gmctrucksrock
gmctrucksrock
ok there is the deal I bought a 95 td 6.5 suburban blown up did the 6.2 lower end and heads and put all the 6.5 stuff on turbo, injector pump, injectors, never timed, bam started right up ran like a dream, so months later I lose the clutch fan and it over heats cracks head so I take good used set of 6.5 heads and regasket at same time I bought a new in package delphi injectors on ebay for 100$ good deal right? then after head job I get this hesitation on starting and some white smoke on start so I buy a remaned injection pump from pensicola deisel install no differance, so I deal with this by running a bypass switch on the tempture sensor so it thinks its cold and to boot I get a high idle on warm up so two months go by still scratching my head oil cooler line blows and motor seizes so I buy a donner truck 93 with manual injection pump and pull motor, and put all my stuff from electronic 6.5 on it, crank sensor, injectors and injector pump now I have the same stumble on start up and I put a clear line on return and after it shuts off I see two tinny bubbles crawl up into the arch of tube so my question being what the hell? Is a injector not shutting down and allowing the air back? the problem started with the injectors being replaced at time of head job and now its still there I replaced fuel lines from lift pump to filter as well as return when i stabbed this last motor all new hoses, but used injector bypass hoses again used the best of the two motors. Any Ideas Guys??????????
