k-bad
i bought a drop in reman. had to return core a year ago and can not remeber where fuel lines go, i got it narrowed down but have a 3/8" pipe about 18 inches long with 90 degree bend on one end that is stumping me. can anyone help?
I suspect that is the line from the Lift Pump to the Fuel Filter manager??
Welcome to the forum! :welcome5:
What year is your truck? If you take the time to fill out your signature, it will help members give you some better help.
Testing my memory (need to go look at my truck). Sounds like the return line that tee's into the right to left bank return line.
It go's under manifold to rear of engine and connect to return line behind FFM.
Does the line you refer to have clips for bolting it down?
thats it!!! it has two clips for mounting it. i assume it connects to the crossover line between the left and right bank.i have intake off and wanted to ensure it went on prior to me seeting the intake. is there any pictures showing this line and where it actually bolts to?
You can just drop on pass side of IP in the valley then install it after the intake is installed.
It would help to know what year as accessories changed side around 95/96
