Front Shocks
Sunshine
Northern Lights
Oslo-Norway
Does any one know the torque specs for the front shocks, Chilton's book gives a force of 60 ft.lbs (90Nm) up to 93 models, I have a 95-k1500-8 lug.
Thanks in advance...
Setting #3 on my Ingersol Rand 2131A impact.
I can't help you with an actual torque spec.
It's a 12mm thread, if that helps.
holy crap, torque specs on shock bolts? next is changing the air in the tires from summer air to winter air...jk
x2:)
I just used a torque wrench for the first time on wheel studs the other day, I retorqued them after a 10 minute drive cause I didn't trust it over my own feel.:hihi:
If you have the same chilton book I do it should be in there, I just did them a few weeks ago. IIRC you're not far off with those 90NM I can check when I get home later but then they're probably done right?
Forgot about this thread ofcourse, I bet those shocks have some miles on them by now...
