GM Guy
Manual Trans. 2WD Enthusiast
hey guys, found on an upcoming farm equipment online auction a 2003 Chevy C3500 D-max ZF6 2wd Reg. Cab 159.5" WB Chassis cab with a mediocre 11' flatbed, but the truck looks very straight, no body imperfections, and oh so very slight surface rust on the frame.
It supposedly has 95,752 miles, but they do show a cluster pic, and the miles are the same as the description, but it has the window for the auto gear selector (with no line under any of the letters). were these known for cluster issues, and the dealer put in and programmed an auto cluster to the mileage? the mileage is just above the last entry in the GM system, which was for the injectors below.
I had ripmf666 run a VIN check, and it did have a full set of injectors from GM in 12/10/09 at 95,481
here is the link to the VIN check
http://www.thetruckstop.us/forum/showthread.php?26646-03-Dmax-6spd-2wd-RC-Chassis-cab
so what do you guys think of the cluster issue? does it sound like what I thought very well could happen?
other than that, what do you guys think of the truck, and what do you think it should be bid to?
