Ford TPS voltage range of TPS ?
Thanks for the links.
I have found out you can basicaly use any TPS that you can get the correct movement of the TPS. If you supply 5v to the tps it can only output 5v at WOT.
Im going to try and use the Isuzu pedal assy w/TPS.
