ripmf666
Registered user
<FORM onsubmit="JavaScript: return true;" method=post name=CellHandlerForm action=/si/cellHandler.do>Document ID: 725147 <HR>
Flywheel Housing Removal
Tools Required
J 37228 Seal Cutter
<LI type=1>Remove the turbocharger oil return pipe nuts from the top of the flywheel housing. <LI type=1>Remove the turbocharger oil return pipe studs.
<LI type=1>Remove the oil cooler adapter nuts. <LI type=1>Remove the oil cooler adapter studs.
Important: The upper oil pan must be removed before removing the flywheel housing.
<LI type=1>Remove the flywheel housing bolts (denoted by a black circle).
<LI type=1>Separate the flywheel housing from the cylinder block using J 37228 . <LI type=1>Remove the flywheel housing. <LI type=1>Remove the turbocharger oil return pipe gasket from the flywheel housing. <LI type=1>Remove the oil cooler adapter bolts.- Remove the oil cooler adapter with gaskets (1, 2).
</FORM>
