nick94
Ok, I am installing a 96 NV4500 on my 94 truck. Should i use the 94 or 96 flywheel. I always thought the flywheel were balanced to the engine? Any advise will be appreciated.:mad2:
I thought 94 was Dual Mass Flywheel. 96 is iffy DMF or solid flywheel depending on build date. The flywheel should be balanced itself. I have replaced with new flywheels w/o balancing. I don't think they are match balanced.
I think you just make sure the components work together the clutch disc, pressure plate, flywheel, slave, and throw out bearing etc .
