Few questions that I cant seam to find with search!! :mad2:
1) 180* thermostat should I get one?? Where can I find one? What brand??
There are a few AC Delco options for the single thermostat, a 180*, 190* and a 195*, I run a 180* and temps are always low, would recommend the 190* or 195*. The 190* is like a double spring or something.
2) where should I install my EGT probe?? anywhere Preturbo, in the crossover is fine if you just want to tap that and weld on a bung or use one of them clamp bung things.
3) where should I tap in to fuel line for fuel PSI??
Between the Filter Manager and the IP makes the most sense so you can see deteriorating filter. The drain line and the top poppet valve location are both pre-filter in the housing.
4) what ells should do seeing as the motor is out?? But about to go back in!
I mentioned before ceramic coatings on the pistons, you can get them that spray on with an air brush and bake at normal stove temps. can do it on tops and a lubrication one on the skirts. Doing the pre-cups would be good too.
5) where can i get injectors rebuilt/tested
Obviously Heath sells them, but with the motor out I would just have the injectors rebuilt, you can find Bosch German, standard or marine nozzles on ebay for $100, and any local diesel shop should have a shim kit and pop tester, or a Mercedes shop might. For installing new nozzles and setting the pop a place only usually charges $15 each or less. So you would have like new for about $220, and can have the pop set to what you want and the type of nozzle you want. I recommend setting the pop to 2200psi on standard nozzles, stock is about 2100psi for a turbo truck.
