ripmf666
Registered user
<FORM onsubmit="JavaScript: return true;" method=post name=CellHandlerForm action=/si/cellHandler.do> Document ID: 666750 <HR>
Exhaust Outlet Removal
<LI type=1>Remove the exhaust outlet heat shield bolts. <LI type=1>Remove the exhaust outlet heat shield. <LI type=1>Remove the exhaust outlet to right exhaust pipe bracket bolt.
<LI type=1>Remove the exhaust outlet bolts and nuts in the proper sequence.
- Remove the exhaust outlet and gasket.
</FORM>
