I thought about going out and starting to remove the bolts, one problem, the sun is in a position to where it is shining through the windows, can not see crap down in the holes with that situation.
I do have another cutting torch/head. The cutting tip runs straight out the end, instead of at a 90* like a normal torch. I did poke that into the hole from on top side, I do think it would work except for one slight problem, aside of being so far down to the top of the flange, it would be a real bear to light the torch then lower it into the hole without burning a bunch of wiring and components. Only other solution would be to lower the torch and then have someone light it from beneath then lift it into position. I know no one that could come and help with such a situation. Everyone I know that could help is plumb messed up with disabilities and I would not call on them to do such a task. Might could get someone hurt, so, off with the maneeefold to do it safely where it can be got to.
