ripmf666
Registered user
<HR>
Engine Block Cleaning and Inspection
Important: All remanufactured cylinder blocks are steel stamped on both sides of the fuel pressure pump boss. The stamp indicates whether the cylinder is standard or over-bored, and if the deck is standard or has been milled.
<TABLE border=1 width="95%"><TBODY><TR><TH vAlign=bottom align=middle>Stamped ID
</TH><TH vAlign=bottom align=middle>Cylinders Bore Size (in.)
</TH><TH vAlign=bottom align=middle>Top Deck (STD or Milled)
</TH></TR><TR><TD vAlign=center align=middle>SS
</TD><TD vAlign=center align=middle>STD
</TD></TR><TR><TD vAlign=center align=middle>01S
</TD><TD vAlign=center align=middle>0.010
</TD></TR><TR><TD vAlign=center align=middle>02S
</TD><TD vAlign=center align=middle>0.020
</TD></TR><TR><TD vAlign=center align=middle>03S
</TD><TD vAlign=center align=middle>0.030
</TD></TR><TR><TD vAlign=center align=middle>SM
</TD><TD vAlign=center align=middle>Milled
</TD></TR><TR><TD vAlign=center align=middle>01M
</TD></TR><TR><TD vAlign=center align=middle>02M
</TD></TR><TR><TD vAlign=center align=middle>03M
</TD></TR></TBODY></TABLE>
<LI type=1>Inspect the block for stampings (1) indicating cylinder overbore or a milled deck. Important: If the block has no stampings, the block has a standard bore and deck.
<LI type=1>Remove the engine block heater. <LI type=1>Remove the O-ring from the block heater and discard.
<LI type=1>Remove the oil gallery plugs.
<LI type=1>Remove the left engine mount bolts. <LI type=1>Remove the left engine mount.
<LI type=1>Remove the right engine mount bolts. <LI type=1>Remove the right engine mount. <LI type=1>Clean the sealing material from the gasket mating surfaces of the block. <LI type=1>Clean the block in cleaning solvent. <LI type=1>Flush the engine block with clean water or steam. <LI type=1>Clean the oil passages. <LI type=1>Clean the cylinder bores. <LI type=1>Inspect the block for cracks. Use the Magnaflux Spot check dye method, or the equivalent.<TABLE border=0><TBODY><TR><TD vAlign=top>• </TD><TD vAlign=top>Inspect the cylinder walls.</TD></TR></TBODY></TABLE>
<TABLE border=0><TBODY><TR><TD vAlign=top>• </TD><TD vAlign=top>Inspect the coolant jackets.</TD></TR></TBODY></TABLE>
<TABLE border=0><TBODY><TR><TD vAlign=top>• </TD><TD vAlign=top>Inspect the crankshaft bearing webs.</TD></TR></TBODY></TABLE>
<LI type=1>Inspect the crankshaft bearing bores and caps. The crankshaft bearing bore inside diameters should be round and uniform at all of the bearing supports. <LI type=1>Inspect the area where the crankshaft bearing inserts contact the crankshaft bearing bore. This area must be free of burrs and scratches. <LI type=1>Inspect the engine mount bosses. <LI type=1>Inspect the cylinder head gasket mating surfaces for pitting.
<LI type=1>Inspect the engine block to cylinder head gasket surface area for warping. Use a straight edge and feeler gauge. Replace the block if it is warped more than 0.15 mm (0.006 in) longitudinally or more than 0.08 mm (0.003 in) transversely. <LI type=1>Apply sealer to the oil gallery plugs.
Notice: Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
<LI type=1>Install the oil gallery plugs. Tighten
Tighten the oil gallery plugs to 53 N·m (39 lb ft).
<LI type=1>Install the left engine block coolant plugs. Tighten
Tighten the left engine block coolant plugs to 18 N·m (13 lb ft).
<LI type=1>Install the right engine block coolant plugs. Tighten
Tighten the right engine block coolant plugs to 18 N·m (13 lb ft).
<LI type=1>Install the left engine mount and engine mount bolts. Tighten
Tighten the engine mount bolts to 58 N·m (43 lb ft).
<LI type=1>Install the right engine mount and engine mount bolts. Tighten
Tighten the right engine mount bolts to 58 N·m (43 lb ft).
<LI type=1>Install a new O-ring to the block heater.- Lubricate the O-ring with engine coolant.
- Install the engine block heater.
