ripmf666
Registered user
<FORM onsubmit="JavaScript: return true;" method=post name=CellHandlerForm action=/si/cellHandler.do>
Document ID: 676025 <HR>
Connecting Rod Bearings Selection Specifications
<A href="http://gsi.xw.gm.com/si/showDoc.do?laborOpCode=&docSyskey=676025&cellId=64269&pubObjSyskey=676025&from=sm&pubCellSyskey=64269#oth1-2382187">Connecting Rod Bearing Grade
<MAP name=2382150.map><TABLE><TBODY><TR><TH align=left></TH></TR><TR><TD align=middle>(1)</TD><TD align=left>First Design</TD></TR><TR><TD align=middle>(2)</TD><TD align=left>Second Design</TD></TR></TBODY></TABLE><TABLE border=1 width="95%"><A href="http://gsi.xw.gm.com/si/showDoc.do?laborOpCode=&docSyskey=676025&cellId=64269&pubObjSyskey=676025&from=sm&pubCellSyskey=64269#tab1-676025">Connecting Rod Bearing Grade
<TBODY><TR><TH vAlign=center rowSpan=2 align=middle>Connecting Rod Grade (Stamped on Connecting Rod)
</TH><TH vAlign=center rowSpan=2 align=middle>Use This Bearing Color
</TH><TH vAlign=bottom colSpan=2 align=middle>Bearing Thickness
</TH><TH vAlign=bottom colSpan=2 align=middle>Oil Clearance
</TH></TR><TR><TH vAlign=center align=middle>Metric (mm)
</TH><TH vAlign=center align=middle>English (in)
</TH><TH vAlign=center align=middle>Metric (mm)
</TH></TR><TR><TD vAlign=center align=middle>A
</TD><TD vAlign=center align=middle>Green
</TD><TD vAlign=center align=middle>2.007 - 2.013
</TD><TD vAlign=center align=middle>0.0790 - 0.0793
</TD><TD vAlign=center align=middle>0.037 - 0.076
</TD><TD vAlign=center align=middle>0.0015 - 0.0030
</TD></TR><TR><TD vAlign=center align=middle>B
</TD><TD vAlign=center align=middle>Yellow
</TD><TD vAlign=center align=middle>2.011 - 2.017
</TD><TD vAlign=center align=middle>0.0792 - 0.0794
© 2010 General Motors. All rights reserved.
</FORM></MAP>
