ripmf666
Registered user
<FORM onsubmit="JavaScript: return true;" method=post name=CellHandlerForm action=/si/cellHandler.do> Document ID: 884033 <HR>
Draining Fluids and Oil Filter Removal
<LI type=1>Drain the fuel from the fuel filter.<TABLE border=0><TBODY><TR><TD vAlign=top>1.1. </TD><TD vAlign=top>Attach drain tube to fuel filter drain tap.</TD></TR></TBODY></TABLE>
<TABLE border=0><TBODY><TR><TD vAlign=top>1.2. </TD><TD vAlign=top>Place open end of drain tube into a suitable container.</TD></TR></TBODY></TABLE>
<TABLE border=0><TBODY><TR><TD vAlign=top>1.3. </TD><TD vAlign=top>Open fuel filter drain, and allow fuel to drain.</TD></TR></TBODY></TABLE>
<TABLE border=0><TBODY><TR><TD vAlign=top>1.4. </TD><TD vAlign=top>Close fuel filter drain.</TD></TR></TBODY></TABLE>
<TABLE border=0><TBODY><TR><TD vAlign=top>1.5. </TD><TD vAlign=top>Remove drain tube.</TD></TR></TBODY></TABLE>
<TABLE border=0><TBODY><TR><TD vAlign=top>1.6. </TD><TD vAlign=top>Properly dispose of used fuel.</TD></TR></TBODY></TABLE>
<LI type=1>Remove the oil drain plug and gasket, and allow engine oil to drain. <LI type=1>Discard the oil drain plug gasket.
<LI type=1>Remove the oil filter.
- Remove the engine block coolant plugs, and allow coolant to drain.
</FORM>
