ripmf666
Registered user
<FORM onsubmit="JavaScript: return true;" method=post name=CellHandlerForm action=/si/cellHandler.do>Document ID: 666740 <HR>
Crankshaft Rear Oil Seal Removal
Tools Required
J 44641 Crankshaft Rear Oil Seal Remover
<LI type=1>Install the button of J 44641 into the crankshaft. <LI type=1>Press the jaws of J 44641 into the felt portion of the seal far enough to engage the inner lip of the seal. <LI type=1>While holding the jaws of J 44641 tightly to the seal's inner sleeve, tighten the jaw bolts.- Remove the crankshaft rear oil seal using the J 44641 .
</FORM>
