DTC Descriptor
DTC 023
DTC 024
DTC 033
DTC 063
DTC 064
DTC 065
DTC B0012, B0013, B0014, B0016, B0017, or B0018 Right Front/Passenger Frontal Deployment Loop (Stage 1) Circuit
DTC B0022, B0024, B0026, B0042, B0043, or B0044 Left Front/Driver Frontal Deployment Loop (Stage 1) Circuit
DTC B0051 Deployment Commanded
DTC B0053 Deployment Commanded with Loop Malfunctions Present
DTC B0083 or B0084 Inflatable Restraint Seat Position Switch Circuit
DTC B0092 Suppression Sensor 1 Circuit Malfunction
DTC B0098 Automatic Occupant Sensing Controller ECU Malfunction
DTC B0100, B0101, B0102, B0103, B0104, or B0105 Electronic Frontal Sensor Circuit
DTC B0159 or B0164 Air Temperature Sensor Circuit
DTC B0174, B0179, B0510, or B0515 Discharge Air Temperature Sensor Circuit
DTC B0183 or B0188 Sunload Sensor Circuit
DTC B0229, B0414, B0424, or B3770 HVAC Door Actuator Range/Performance
DTC B0263, B0268, B0408, or B0418 HVAC Door Actuator Circuit
DTC B0263, B0408, or B0418 HVAC Door Actuator Circuit
DTC B0283 Electric Rear Defrost Circuit
DTC B0414, B0424, or B3770 HVAC Door Actuator Range/Performance
DTC B0540 Speedometer Circuit
DTC B0560 Tachometer Circuit Range/Performance
DTC B0775 Four Wheel Drive High Range (4HI) Indicator Circuit
DTC B0780 Four Wheel Drive Low Range (4LO) Indicator Circuit
DTC B0785 Two Wheel Drive High Range (2HI) Indicator Circuit
DTC B0790 Transfer Case Neutral Indicator Circuit
DTC B0951 Headlamps On Indicator Circuit
DTC B1000 ECU Malfunction
DTC B1001 Option Configuration Error
DTC B1004 Keep Alive Memory (KAM) Reset
DTC B1007 EEPROM Write Error
DTC B1009 EEPROM Checksum Mismatch
DTC B1023 Integral Switch Performance
DTC B1025, B1035, B1045, or B1055 Audio [+] Output Circuit
DTC B1235 Amplifier On Signal Circuit
DTC B1259 Antenna Ground Circuit
DTC B1372 Device Ignition 1 (ON and START) Circuit Low
DTC B1375 Device Ignition 3 (ON) Circuit
DTC B1440 Power Mode Master Input Circuits Mismatch
DTC B1480 Battery Rundown Protection Circuit Malf
DTC B1544, B1600, or B1605 Mirror Motors Common Circuit
DTC B1580, B1590, B1610, or B1620 Mirror Position Sensor Circuit
DTC B1640 or B1645 Mirror Heater Circuit
DTC B1722 Mirror Power Fold Control Circuit
DTC B1735, B1740, B1745, B1750, B1755, B1760, B1815, B1820, B1830, B1835, B1840, B1845, B1940, or B1945 Seat Switch Circuit
DTC B1770, B1775, B1780, B1785, B1790, B1805, or B2415 Seat Motor(s) Overcurrent
DTC B1825 Seat Recline Position Sensor Circuit
DTC B1850, B1860, B1960, B2355, B2365, or B2375 Seat Position Sensor Circuit
DTC B2425 or B2430 Seat Heater Circuit
DTC B2435 or B2440 Seat Back Heater Sensor Circuit
DTC B2455 Cellular Phone Microphone Circuit
DTC B2470 Cellular Phone Antenna Circuit
DTC B2476 Cellular Phone Select Service Switch Malfunction
DTC B2482 Cellular Phone Select Service Switch Range/Performance
DTC B2483 or B2484 Global Positioning System (GPS) Sensor Circuit
DTC B2527 Front Fog Lamp Circuit Low
DTC B2530 Front Foglamps Control Circuit
DTC B2540 Rear Foglamps Control Circuit
DTC B2550 Backup Lamps Control Circuit
DTC B2575 Headlamp Control Circuit
DTC B2580 Headlamp High Beam Control Circuit
DTC B2585 Parklamp Control Circuit Malfunction
DTC B2600 Daytime Running Lamp Control Circuit
DTC B2610 Passenger Compartment 1 Dimming Circuit
DTC B2615 Passenger Compartment Dimming 2 Circuit
DTC B2620 Display Dimming Pulse Width Modulation (PWM) Input Circuit
DTC B2625 Display Dimming Pulse Width Modulation (PWM) Output Circuit
DTC B2645 Ambient Light Sensor Circuit
DTC B2725 ATC Mode Switch Circuit Malfunction
DTC B2752 Horn Relay Coil Circuit Low
DTC B2815 Steering Wheel Controls Illegal Resistance Value
DTC B2947 Security System Sensor Power CKT Low
DTC B2948 Security System Sensor Power CKT High
DTC B2957 Security System Sensor Data Circuit Low
DTC B2958 Security System Sensor Data Circuit High
DTC B2960 Sec Sys Sensor Data Incorrect but Valid
DTC B2961 Key In Ignition Circuit Malfunction
DTC B3031 Security System Controller in Learn Mode
DTC B3033 Security System Indicates Tamper
DTC B3102 Keyless Entry Data Link Circuit Low
DTC B3593 Steering System Mode Switch Circuit
DTC B3801 Passenger Compartment Lamp Request Circuit
DTC B3802 Parklamps Request Circuit
DTC B3808 Rear Door Lock Relay Circuit
DTC B3809 Rear Door Unlock Relay Circuit
DTC B3819 Left Rear Window Up Control Circuit
DTC B3820 Left Rear Window Down Control Circuit
DTC B3821 Left Rear Window Relay Power Circuit
DTC B3822 Right Rear Window Up Control Circuit
DTC B3823 Right Rear Window Down Control Circuit
DTC B3824 Right Rear Window Relay Power Circuit
DTC B3841 Front Seat Heaters Circuit
DTC B3962 Seat Motor(s) Overcurrent
DTC C0000 Vehicle Speed Information Circuit
DTC C0035 or C0040 Front Wheel Speed Sensor Circuit
DTC C0055 Rear Wheel Speed Sensor Circuit
DTC C0110 Pump Motor Circuit
DTC C0161 Antilock Brake System (ABS)/Traction Control System (TCS) Brake Switch
DTC C0186 Lateral Accelerometer Circuit
DTC C0196 Yaw Rate Circuit
DTC C0201 Antilock Brake System (ABS) Enable Relay Contact Circuit
DTC C0221-C0227 Front Wheel Speed Sensor Circuit
DTC C0229 Drop Out of Front Wheel Speed Signals
DTC C0235-C0237 or P0609 Rear Wheel Speed Sensor Circuit
DTC C0238 Wheel Speed Mismatch
DTC C0241-C0254 EBCM Control Valve Circuit
DTC C0253 Centering Error
DTC C0265 or C0266 EBCM Relay Circuit
DTC C0267 or C0268 Pump Motor Circuit Open/Shorted
DTC C0269 or C0274 Excessive Dump/Isolation Time
DTC C0271-C0273, C0284 EBCM Malfunction
DTC C0279 Powertrain Configuration Not Valid
DTC C0281 Brake Switch Circuit
DTC C0283 Traction Switch Shorted to Ground
DTC C0287, P1644, or P1689 Delivered Torque Circuit
DTC C0290 or C0292 Lost Communications With PCM
DTC C0291 Lost Communications With BCM
DTC C0297 Powertrain Configuration Data Not Received
DTC C0298 or P1571 Powertrain Indicated Traction Control Malfunction
DTC C0300 Rear Speed Sensor Malfunction
DTC C0305 Front Speed Sensor Malfunction
DTC C0306 Motor A or B Circuit
DTC C0321 Transfer Case Lock Circuit
DTC C0327 Encoder Circuit Malfunction
DTC C0359 Four Wheel Drive Low Range (4LO) Discrete Output Circuit
DTC C0374 General System Malfunction
DTC C0379 Front Axle System
DTC C0455 Front Steering Position Sensor Circuit
DTC C0472 or C0473 Steering Handwheel Speed Sensor Signal Circuit
DTC C0522 Rear Steering Position Sensor Circuit
DTC C0527 Rear Steering Motor Position Sensor Circuit
DTC C0532 Rear Steering Position and Motor Position Sensors Uncorrelated
DTC C0533 Rear Steering Motor Relay Circuit
DTC C0538 Rear Steering Motor Circuit
DTC C0543 Rear Steering Motor Position Error
DTC C0550 ECU Malfunction
DTC P0016 Crankshaft Position (CKP)-Camshaft Position (CMP) Correlation
DTC P0087 Fuel Rail Pressure (FRP) Too Low
DTC P0088 Fuel Rail Pressure (FRP) Too High
DTC P0089 Fuel Pressure Regulator Performance
DTC P0090 Fuel Pressure Regulator Control Circuit
DTC P0101 Mass Air Flow (MAF) Sensor Performance
DTC P0102 Mass Air Flow (MAF) Sensor Circuit Low Frequency
DTC P0103 Mass Air Flow (MAF) Sensor Circuit High Frequency
DTC P0106 Manifold Absolute Pressure (MAP) Sensor Performance
DTC P0107 Manifold Absolute Pressure (MAP) Sensor Circuit Low Voltage
DTC P0108 Manifold Absolute Pressure (MAP) Sensor Circuit High Voltage
DTC P0112 Intake Air Temperature (IAT) Sensor Circuit Low Voltage
DTC P0113 Intake Air Temperature (IAT) Sensor Circuit High Voltage
DTC P0116 Engine Coolant Temperature (ECT) Sensor Performance
DTC P0117 Engine Coolant Temperature (ECT) Sensor Circuit Low Voltage
DTC P0118 Engine Coolant Temperature (ECT) Sensor Circuit High Voltage
DTC P0120 Throttle Position (TP) Sensor 1 Circuit
DTC P0121 TP Sensor Circuit Insufficient Activity
DTC P0122 Throttle Position (TP) Sensor Circuit Low Voltage
DTC P0123 Throttle Position (TP) Sensor Circuit High Voltage
DTC P0125 Engine Coolant Temperature (ECT) Insufficient for Closed Loop Fuel Control
DTC P0128 Engine Coolant Temperature (ECT) Below Thermostat Regulating Temperature
DTC P0131 or P0151 HO2S Circuit Low Voltage
DTC P0132 or P0152 HO2S Circuit High Voltage
DTC P0133 or P0153 HO2S Slow Response
DTC P0134 or P0154 HO2S Circuit Insufficient Activity
DTC P0135 or P0155 HO2S Heater Performance
DTC P0135, P0141, P0155, or P0161 HO2S Heater Performance
DTC P0137 or P0157 HO2S Circuit Low Voltage
DTC P0138 or P0158 HO2S Circuit High Voltage
DTC P0140 or P0160 HO2S Circuit Insufficient Activity
DTC P0141 or P0161 HO2S Heater Performance
DTC P0168 Engine Fuel Overtemperature
DTC P0171 or P0174 Fuel Trim System Lean
DTC P0172 or P0175 Fuel Trim System Rich
DTC P0181 Fuel Temperature Sensor Performance
DTC P0182 Fuel Temperature Sensor Circuit Low Voltage
DTC P0183 Fuel Temperature Sensor Circuit High Voltage
DTC P0192 Fuel Rail Pressure (FRP) Sensor Circuit Low Voltage
DTC P0193 Fuel Rail Pressure (FRP) Sensor Circuit High Voltage
DTC P0200 Injector Control Circuit
DTC P0201-P0208 Injector Control Circuit
DTC P0220 Throttle Position (TP) Sensor 2 Circuit
DTC P0230 Fuel Pump Relay Control Circuit
DTC P0234 Engine Overboost
DTC P0236 Turbocharger Boost System Performance
DTC P0237 Turbocharger Boost Sensor Circuit Low Voltage
DTC P0238 Turbocharger Boost Sensor Circuit High Voltage
DTC P0300 Engine Misfire Detected
DTC P0301-P0308 Engine Misfire Detected
DTC P0315 Crankshaft Position (CKP) System Variation Not Learned
DTC P0325 Knock Sensor Module Performance
DTC P0327 Knock Sensor (KS) 1 Circuit
DTC P0327 or P0332 Knock Sensor Circuit
DTC P0335 Crankshaft Position (CKP) Sensor Circuit
DTC P0336 Crankshaft Position (CKP) Sensor Performance
DTC P0340 Camshaft Position (CMP) Sensor Circuit
DTC P0341 Camshaft Position (CMP) Sensor Performance
DTC P0342 Camshaft Position (CMP) Sensor Circuit Low Voltage
DTC P0343 Camshaft Position (CMP) Sensor Circuit High Voltage
DTC P0351 Ignition Coil 1 Control Circuit
DTC P0351-P0358 Ignition Coil Control Circuit
DTC P0370 or P0374 High Resolution Circuit
DTC P0380 Glow Plug Feedback Circuit
DTC P0381 Wait to Start Lamp Control Circuit
DTC P0401 Exhaust Gas Recirculation (EGR) Flow Insufficient
DTC P0404 Exhaust Gas Recirculation (EGR) Open Position Performance
DTC P0405 Exhaust Gas Recirculation (EGR) Position Sensor Circuit Low Voltage
DTC P0406 Exhaust Gas Recirculation (EGR) Position Sensor Circuit High Voltage
DTC P0420 or P0430 Catalyst System Low Efficiency
DTC P0442 Evaporative Emission (EVAP) System Small Leak Detected
DTC P0443 Evaporative Emission (EVAP) Purge Solenoid Control Circuit
DTC P0446 Evaporative Emission (EVAP) Vent System Performance
DTC P0449 Evaporative Emission (EVAP) Vent Solenoid Control Circuit
DTC P0452 Fuel Tank Pressure Sensor Circuit Low Voltage
DTC P0453 Fuel Tank Pressure Sensor Circuit High Voltage
DTC P0455 Evaporative Emission (EVAP) System Large Leak Detected
DTC P0461 Fuel Level Sensor Performance
DTC P0462 Fuel Level Sensor Circuit Low Voltage
DTC P0463 Fuel Level Sensor Circuit High Voltage
DTC P0489 Exhaust Gas Recirculation (EGR) Solenoid Control Circuit Low Voltage
DTC P0490 Exhaust Gas Recirculation (EGR) Solenoid Control Circuit High Voltage
DTC P0496 Evaporative Emission (EVAP) System Flow During Non-Purge
DTC P0506 Idle Speed Low
DTC P0506 or P0507 Incorrect Idle Speed
DTC P0507 Idle Speed High
DTC P0522 Engine Oil Pressure (EOP) Switch Circuit Low Voltage
DTC P0523 Engine Oil Pressure (EOP) Sensor Circuit High Voltage
DTC P0530 Air Conditioning (A/C) Refrigerant Pressure Sensor Circuit
DTC P0540 Intake Air (IA) Heater Feedback Circuit
DTC P0543 Intake Air (IA) Heater Element Open
DTC P0562 System Voltage Low
DTC P0563 System Voltage High
DTC P0567 Cruise Control Resume Switch Circuit
DTC P0568 Cruise Control Set Switch Circuit
DTC P0571 Cruise Control Brake Switch Circuit
DTC P0601-P0607, P1600, P1621, P1627, P1680, P1681, P1683, or P2610 ECU Malfunction
DTC P0608 Vehicle Speed Output Circuit
DTC P0611 Fuel Injector Control Module Performance
DTC P0612 Fuel Injector Control Module Relay Control Circuit
DTC P0615 Starter Relay Control Circuit
DTC P0621 Generator L-Terminal Circuit
DTC P0622 Generator F-Terminal Circuit
DTC P0641 5 Volt Reference 1 Circuit
DTC P0650 Malfunction Indicator Lamp (MIL) Control Circuit
DTC P0651 5 Volt Reference 2 Circuit
DTC P0654 Engine Speed Output Circuit
DTC P0700 Transmission Control Module (TCM) Requested MIL Illumination
DTC P0802 Transmission Control Module (TCM) MIL Request Circuit
DTC P1093 Fuel Rail Pressure Low During Power Enrichment
DTC P1094 Fuel Rail Pressure Low During Idle or Decel Fuel Cut-Off (DFCO)
DTC P1106 Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent High Voltage
DTC P1107 Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent Low Voltage
DTC P1111 Intake Air Temperature (IAT) Sensor Circuit Intermittent High Voltage
DTC P1112 Intake Air Temperature (IAT) Sensor Circuit Intermittent Low Voltage
DTC P1114 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent Low Voltage
DTC P1115 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent High Voltage
DTC P1121 Throttle Position (TP) Sensor Circuit Intermittent High Voltage
DTC P1122 Throttle Position (TP) Sensor Circuit Intermittent Low Voltage
DTC P1125 Accelerator Pedal Position (APP) System
DTC P1133 or P1153 HO2S Insufficient Switching
DTC P1172 Sec Fuel Pump Insufficient/No Fuel Flow
DTC P1223, P1226, P1229, P1232, P1235, P1238, P1241, or P1244 Injector Output Circuit
DTC P1258 Engine Coolant Overtemperature - Protection Mode Active
DTC P1270 Accelerator Pedal Position (APP) Sensor Analog to Digital Performance
DTC P1380 Misfire Detected - Rough Road Data Not Available
DTC P1381 Misfire Detected - No Communication with Brake Control Module
DTC P1404 Exhaust Gas Recirculation (EGR) Closed Position Performance
DTC P1514 Throttle Body Performance
DTC P1515 Control Module Throttle Actuator Position Performance
DTC P1516 Throttle Actuator Control (TAC) Module Throttle Actuator Position Performance
DTC P1518 Throttle Actuator Control (TAC) Module Serial Data Circuit
DTC P1550 Fuel Injector Control Module System Voltage
DTC P1574 Stoplamp Switch Circuit
DTC P1626 Theft Deterrent Fuel Enable Signal Lost
DTC P1631 Theft Deterrent Start Enable Signal Not Correct
DTC P1637 Generator L-Terminal Circuit
DTC P1638 Generator F-Terminal Circuit
DTC P1658 Fuel Injector Control Module Driver Performance
DTC P2066 Fuel Level Sensor 2 Performance
DTC P2067 Fuel Level Sensor 2 Circuit Low Voltage
DTC P2068 Fuel Level Sensor 2 Circuit High Voltage
DTC P2108 Throttle Actuator Control (TAC) Module Performance
DTC P2120 Accelerator Pedal Position (APP) Sensor 1 Circuit
DTC P2121 Accelerator Pedal Position (APP) Sensor 1 Performance
DTC P2122 Accelerator Pedal Position (APP) Sensor 1 Circuit Low Voltage
DTC P2123 Accelerator Pedal Position (APP) Sensor 1 Circuit High Voltage
DTC P2125 Accelerator Pedal Position (APP) Sensor 2 Circuit
DTC P2127 Accelerator Pedal Position (APP) Sensor 2 Circuit Low Voltage
DTC P2128 Accelerator Pedal Position (APP) Sensor 2 Circuit High Voltage
DTC P2132 Accelerator Pedal Position (APP) Sensor 3 Circuit Low Voltage
DTC P2133 Accelerator Pedal Position (APP) Sensor 3 Circuit High Voltage
DTC P2135 Throttle Position (TP) Sensor 1-2 Correlation
DTC P2138 Accelerator Pedal Position (APP) Sensor 1-2 Correlation
DTC P2139 Accelerator Pedal Position (APP) Sensor 1-3 Correlation
DTC P2140 Accelerator Pedal Position (APP) Sensor 2-3 Correlation
DTC P2141 Exhaust Gas Recirculation (EGR) Throttle Valve Solenoid Control Circuit Low Voltage
DTC P2142 Exhaust Gas Recirculation (EGR) Throttle Valve Solenoid Control Circuit High Voltage
DTC P2144 Exhaust Gas Recirculation (EGR) Vent Solenoid Control Circuit Low Voltage
DTC P2145 Exhaust Gas Recirculation (EGR) Vent Solenoid Control Circuit High Voltage
DTC P2146 Injector Positive Voltage Control Circuit Group 1
DTC P2149 Injector Positive Voltage Control Circuit Group 2
DTC P2227 Barometric Pressure (BARO) Sensor Performance
DTC P2228 Barometric Pressure (BARO) Sensor Circuit Low Voltage
DTC P2229 Barometric Pressure (BARO) Sensor Circuit High Voltage
DTC P2279 Intake Air (IA) Duct Air Leak
DTC U1000 and U1255 Class 2 Communication Malfunction
DTC U1001-U1254 Loss of XXX Communications
DTC U1300, U1301, or U1305 Class 2 Data Link Shorted
DTC U1305 Class 2 Data Link Low or High
DTC U1500 Inter-device Dedicated Bus 1
DTC U1800 Lost Communications With Fuel Injector Control Module (FICM)
DTC U2104 Controller Area Network (CAN) Bus Reset Counter Overrun
DTC U2106 Lost Communications With Transmission Control System
