Can code 19 cause no start? No Fuel to injectors. Fuel is getting to pump but nothing is coming out.
Truck had occasional fisbite here and there. Then one day it died at stoplight . Took a littlebit to get it back up running probably 10 min .Was right around the corner from work and it made it there . Made it home that evening . Acted like it wanted to die while braking close to the house but it made it. Next day it started for like 2 seconds and died. Hasnt ran since.
Fuel shut off solenoid has had plunger taken out to eliminate that , fuel comes out where solenoid goes when lift pump is on .
Pmd was not relocated at time of trouble so i got a kit from Leroy. Battery teminals cleaned and reinstalled . Got code 12 for days while cranking here and there. No start .After about a week got code 19 .
Can crankshaft sensor be whats keeping fuel from injectors?
1994 c1500 single tire . s code . Got the lift pump for 93 model, leroys lp relay harness, leroys pmd relocation . I have deleted ffm and have put a fuel filter and water separator up on firewall. Harnesses from ffm are not hooked up to anything now, being obd1 i dont think that should effect anything .
Anyone have any suggestions?
