Cheap ramps
Matt Bachand
Depends on the 6.5
Worcester, MA
I made these a year ago when I wish I had some ramps.
Just 2x6's cut at a 45, lowest one is longer so weight of truck holds em in place, no slide. I 4low up em, could make them longer on top if scared of going off. These work great, and the extra 6 inches is awesome for working underneath.
Best thing is, they will NEVER, ever, break with me underneath the rig.
Good idea. A 2x10 for the bottom and stacked 2x8's would make for more stability. If you got real creative you could make them higher as well.
Defanately, i only had 2 2x6's kicking around so thats what I used. I wanted longer at top, but my last pieces of wood were only that long, so instead of adding to the bottom, i had to add to the top. These aren't your beginner's ramps, not a good spot for a PMD surge :), but they work well and cost practically nothing.
And for someone reading that may not know, an extra 6 inches of room under the rig makes all the difference in the world when you are under there.
Surprising what you can get out of a tree..
I say to my kids "Do You Think Money Grows On Trees" yes does coz that's were it come from..:iamwithstupid:
Looks scarey to me. I'm a believer in a jack and jackstands.I've had ramps tip over.
DRW in 4-Low, shes not sliding, tipping, falling, rolling, moving.
I use for underneath cleaning, greasing, oil changing, (even pitches the oil back to the bung a bit)
Finding ramps that I would trust this kind of weight on would be expensive, and probably large and heavy.
I use a 12 ton bottle jack to lift any tire on this truck, my 2 1/2 ton jack barely lifts any tire off the ground and takes all my might to jack it up. Now, that is scary.
I haven't seen boughten ramps that could handle that kind of weight. I'd build my own. I was a welder for 20 years. I built my own engine hoist. Most boughten ones wouldn't lift high enough.
shoulda put something at the end so's ya don't go up and over the end. i have a set of custom made aluminum ramps that are 12 inches wide and it has a small little piece to stop me from going over the other side. still i worry about overshooting it. and go up in 4 low. Ed
I made my own set of ramps but for my Impala I use to have. It was to low to drive up a set of ramps so to make life easier I used 3/4 plywood the bottom was about 36 inches long and 8 inches wide. They had to be long in order to fit under the car so I could get up them. Then I kept stacking 3/4 plywood about 2 inches shorter then the last until I was about 5 inches high. just high enough to crawl under and reach my arm under there to change the oil and things.
