Darkrider
Lobo Solitario
Ok...since it looks like i will be hanging onto my '69 GMC C10, I need to sort out my options for brakes with this thing. It currently has the Power drum brake set up on it and i am not sure if i can make the Hydraboost booster work in place of the Vac booster. If i was going disk brakes it would be a no brainer then its just a matter of swapping the entire Hydraboost set up on M/C and all. The problem lays in the fact that the truck is a 6 lug drum brake and unless i get into expensive conversion parts or go on a search for C20 lower control arms to make a GMT400 brake set up work im stuck with going 5 lug. One option i suppose is to go 5 lug front and just live with the rear being 6 lug. Sort of like how the C3500 HDs had the wide 5 lug fronts with the 8 lug rears. Im wondering though if there is a way to just use the vac system with the 6.2 though?
